15 years agoJTAG USB dropping data when printing to terminal
I've got a system setup to print out ADC samples via a NIOS processor (standard) and JTAG USB. The ADC samples at 48Khz and the samples are streamed to the NIOS processor to be printed through PIO. ...
15 years agoThe JTAG uart isn't a very fast interface, so you are probably reaching its limit.
It isn't very easy to do a custom USB endpoint on the development kits, so if you have lots of data to stream it could be a good idea to use an interface such as Ethernet to transmit it to the PC.
