11 years agoJTag programming
Hi, We are currently using the USB Blaster and Quartus software to download the FPGA code to Max 10 Nios board. In the next phase the Nios board would be connected via Jtag cable to another l...
11 years agoIf you don't want to use a configuration device it is also possible to send to configuration to the FPGA from the linux system using passive serial. It's a lot easier than JTAG and more documented. I've never used the jam player myself but from what I've heard it's not easy to get it to work...
