16 years agoJFFS2 kernel support
Hello all
I'm trying to add jffs2 support to a kernel (3c120 dev board) and I'm facing an strange problem. If I checked in jffs2 support in menuconfig, _after_ compiling the kernel core and _while compiling_ the apps , the compile process barfs
|| ( touch mtd-utils/.sgbuilt_user && make -C mtd-utils ) || exit $?
make: se ingresa al directorio `/home/eugenio/uCLinux-MMU/nios2-linux/uClinux-dist/user/mtd-utils'
unset CC CFLAGS CPPFLAGS CROSS LDFLAGS; make -C 606f38a2221648ca5c5fa292c9f71d2ddd59fa66/ WITHOUT_XATTR=1 SUBDIRS= BUILDDIR=$PWD/build-606f38a2221648ca5c5fa292c9f71d2ddd59fa66-host/ TARGETS=" mkfs.jffs2"
make: se ingresa al directorio `/home/eugenio/uCLinux-MMU/nios2-linux/uClinux-dist/user/mtd-utils/606f38a2221648ca5c5fa292c9f71d2ddd59fa66'
mkdir -p /home/eugenio/uCLinux-MMU/nios2-linux/uClinux-dist/user/mtd-utils/build-606f38a2221648ca5c5fa292c9f71d2ddd59fa66-host/
gcc -I./include -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /home/eugenio/uCLinux-MMU/nios2-linux/uClinux-dist/user/mtd-utils/build-606f38a2221648ca5c5fa292c9f71d2ddd59fa66-host/compr_lzo.o compr_lzo.c -g -Wp,-MD,/home/eugenio/uCLinux-MMU/nios2-linux/uClinux-dist/user/mtd-utils/build-606f38a2221648ca5c5fa292c9f71d2ddd59fa66-host/.compr_lzo.c.dep
compr_lzo.c:29:23: error: lzo/lzo1x.h: No existe el fichero o el directorio
compr_lzo.c: In function ‘jffs2_lzo_cmpr’:
compr_lzo.c:51: error: ‘lzo_uint’ undeclared (first use in this function)
compr_lzo.c:51: error: (Each undeclared identifier is reported only once
compr_lzo.c:51: error: for each function it appears in.)
compr_lzo.c:51: error: expected ‘;’ before ‘compress_size’
compr_lzo.c:54: warning: implicit declaration of function ‘lzo1x_999_compress’
compr_lzo.c:54: error: ‘compress_size’ undeclared (first use in this function)
compr_lzo.c:56: error: ‘LZO_E_OK’ undeclared (first use in this function)
The strange thing is that it tries to compile mkfs.jffs2 using my x86 gcc compiler :confused: If I try to disable mtd-utils, it doesn't mind; same error while compiling mkfs.jffs2 in mtd-utils which I have previously disabled.... Adding kernel support for MTD and user apps. support for mtd-utils works fine. No errors. It only happens when adding jffs2 kernel support and while compiling mkfs.jffs2 (mtd-utils enabled or not) Any hints? TIA
