15 years agoIt spend too much time to run
HI,sometimes i found such problems.After i have build the project,it still take more than 3 minutes before it start runing as NIOS ii hardware.However sometime it is so quickly(less than 30 seconds) ...
15 years agoIt seems you have date issue,check the date of your project and match it with your system date.Sometimes when we click "run as hardware",because of this date mismatches,it again builds and then execute all the time.
So you compile again in quartus by generating SOPC also and then again RUN in nios II.
