10 years agoIt is possible to run altera_avalon_uart at 921600 bps?
It is possible to run altera_avalon_uart at 921600 bps instead of 115200? QSys GUI have only 115200 but with some code there is possibility? Thanks
10 years agoFor what it's worth, 921600 with a 25MHz or 50MHz clkin commonly used on the eval boards has zero error and no warning from the script.
Should you care for an even more odd-ball baud rate, the only thing you should need to have to do is e.g. use a PLL to supply a clkin as an integral multiple of the baud rate.
