10 years agoIt is possible to run altera_avalon_uart at 921600 bps?
It is possible to run altera_avalon_uart at 921600 bps instead of 115200? QSys GUI have only 115200 but with some code there is possibility? Thanks
10 years agoThe limitation comes from the baud ALLOWED_RANGE property in the _hw.tcl of that module, and I believe it is only restricting you when creating a component with fixed baud rate.
There are many ways to work around it: don't use fixed baud rate, clone and modify the Altera supplied copy of the module, or don't do any of the above and just supply it with 8x the clock you told it you would give it.
