NIOS2User
3 years agoIssues while burning code on NIOS II Development kit
I tried to burn a Verilog code on NIOS II development kit (EP2C35F672C6N). Here in Quartus software, it is showing the FPGA programmed successfully, but the default program is running on the kit, and ...
KellyJialin_Goh
3 years agoHi,
Any updates from your side on deleting the default code and only enable your coding file.
Have you also checked out on the booting methods as the issue might also rely on when your are programming your .sof/.jic file into your Cyclone II.
Hope to hear from you soon.
Thank you.
Kelly
