NIOS2User
3 years agoIssues while burning code on NIOS II Development kit
I tried to burn a Verilog code on NIOS II development kit (EP2C35F672C6N). Here in Quartus software, it is showing the FPGA programmed successfully, but the default program is running on the kit, and ...
KellyJialin_Goh
3 years agoHi,
Welcome to Intel's forum.
I am glad you have successfully programmed your FPGA with the .v file you have but to indicate whether it is programmed like what you mentioned, you may go back to your project file directory, under the output file, check and see whether a .sof file is generated or not. But given your statement, I believe the .sof file is already in your output file directory and meaning it is successfully programmed to your FPGA.
Hope this could clear your doubts.
Thank you.
Kelly
