Issue in Nios Eclipse : elf not generated
- 6 years ago
I just ran into this issue and found your post while googling for a solution. For me a perfectly functional project just stopped working. The root cause is that the wslpath program (used to translate between Linux and Windows paths in WSL) seems to have changed. I took OS updates this morning so that is the only explanation I have. Your Makefile is trying to basically do this:
wslpath -m hal_bsp
I'm guessing this just used to return simply "hal_bsp" because other ways of calling wslpath still seem to return this string. Now it is the reason you see:
"wslpath: hal_bsp: No such file or directory"
in your output. I'm not sure why the Makefile tries to translate this string. To fix it, open your project Makefile and look for a line like this:
APP_LDFLAGS += -msys-lib=$(call adjust-path-mixed,$(SYS_LIB))
For me it's around line 326, but is probably a bit different for you. Change it to:
APP_LDFLAGS += -msys-lib=hal_bsp
After this your project will build again.
wslpath -m hal_bsp
thanks a lot for your help
It's works now.
