20 years agoIs using a single 25MHz oscillator feasible
We're starting to design a custom board using a Stratix II part and we'd like the board to be as small as possible. The board will have an ethernet device, SRAM, CFI flash, and the MAX progra...
20 years ago --- Quote Start --- originally posted by jdhar@Jul 5 2006, 01:51 PM the only potential issue i have had was deriving the right frequencies; that's why i usually have two slots, one for a 50m and one for a 48m... they can get you different time bases. if you can get all of your frqeuencies with the one, then you should be ok. the only case i could see forming a problem was if you needed multiple output clocks from the fpga; you would ideally use the outputs of a pll for these clocks, and theres only one external output per pll... so keep that in mind too
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16676)
--- quote end ---
--- Quote End --- We're driving all the internal logic with the same clock so that shouldn't be an issue. The only frequencies we'll need are 25MHz and 50, 75, or 100.
