LeninReborn
4 years agoIP initialization problem
Hello to all. Wrote an application to exchange packets between FPGA and PC using TCP / IP NicheStack. FPGA is using Cyclone III and the whole program runs from external SRAM. The project starts su...
Lenin_Reborn
4 years agoFound an error due to which memory was not allocated.
Everything boots successfully now. There is just one problem. Nios will only start if you run nios2-terminal. Doesn't work without a terminal. What could be the reason?
