16 years agoIOWR, IOWR_32DIRECT, alt_flash_read... need help to get the bits
I have got a quite simple problem I think, but I am messing around about half a day now with that and don't figure it out. So I would like to ask for your advice.
I want to copy data from my EPCS Flash to a SDRAM. I can do it with this rather ugly method:
int i;
char read_data;
for(i=0; i<size; i++){
//in
ret_code = alt_read_flash(my_epcs, i<<2, &(read_data), 1);
ret_code = alt_read_flash(my_epcs, (i<<2)+1, &(read_data), 1);
ret_code = alt_read_flash(my_epcs, (i<<2)+2, &(read_data), 1);
ret_code = alt_read_flash(my_epcs, (i<<2)+3, &(read_data), 1);
//out
IOWR_8DIRECT((SDRAM_2_MASK0_BASE+3), ((i-1)*32/8), read_data);
IOWR_8DIRECT((SDRAM_2_MASK0_BASE+2), ((i-1)*32/8), read_data);
IOWR_8DIRECT((SDRAM_2_MASK0_BASE+1), ((i-1)*32/8), read_data);
IOWR_8DIRECT((SDRAM_2_MASK0_BASE) , ((i-1)*32/8), read_data);
Can someone give me a working example how to do this with 32bit directly? Everytime I try it with IOWR it get messed up. My C-knowledge isn't so well, so I think I mess up with the pointers and adresses some kind of. Thanks in advance, I really need this urgently.5 Replies
You can use alt_read_flash right into SDRAM in one call. I do this currently on startup to copy the application in EPCS to SDRAM - with one call and a tricky jump to the entry point.
Billret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); - Altera_Forum
Thanks for your reply BillA. I already tried that, but did not matched the addresses right I think.
Does alt_read_flash read Bytes or Bits? So dataSize*8=Bit or dataSize=Bit?
I have got a EPCS64 Serial Device and my SDRAM Master Width is 32Bit wide. How would you count?ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize);
:confused: :confused:epcsAddr++, sdramAddr++, dataSize = 32 ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); or epcsAddr+=4, sdramAddr++, dataSize = 32 ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); or epcsAddr+=32, sdramAddr++, dataSize = 32 ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); or epcsAddr+=4, sdramAddr++, dataSize = 4 ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); - Altera_Forum
Everything is in bytes. datasize is a number of bytes, and the addresses point to bytes in memory (i.e. you need to increase them by 4 to jump to the next 32-bit word, as long as they are ints or char*).
--- Quote Start --- Thanks for your reply BillA. I already tried that, but did not matched the addresses right I think. Does alt_read_flash read Bytes or Bits? So dataSize*8=Bit or dataSize=Bit? --- Quote End --- Bytes. I don't know if there is optimization to write 32-bits at a time to SDRAM but the call is bytes (like C's fread) and the EPCS contents are placed byte for byte in order. --- Quote Start --- I have got a EPCS64 Serial Device and my SDRAM Master Width is 32Bit wide. How would you count? --- Quote End --- Use the following to read 32 bytes at a time. But there's no reason to do this - one call will suffice - dataSize is the bytes to copy. Look at alt_read_flash as if it were memcpy:
Billwhile(dataSize>32) { ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, 32); epcsAddr+=32, sdramAddr+=32; dataSize-=32; } if(dataSize>0) ret_code = alt_read_flash(my_epcs, epcsAddr, sdramAddr, dataSize); - Altera_Forum
Thanks for your help, tried it out today and just works fine.
Yours, Peter.
