Dolemy
3 years agoIOWR and IORD Problem (with Image)
Hello! I am having difficulty using the IOWR and IORD functions in NIOS II. I have created a custom Uart Tx IP and I want to communicate with my computer through it. then, I have included it in NI...
EBERLAZARE_I_Intel
3 years agoHi,
Do you have any update?
- Dolemy3 years ago
Thank you.
I received your answer well.
Even after modifying the code according to your answer and debugging it, the same problem occurs.
I think the problem is that I made my CUSTOM IP incorrectly.
If it’s not too much trouble, could you tell me how to make a CUSTOM IP using the UART_TX HDL code I’m providing?
I will write my HDL code for this purpose. I will also attach other HDL codes I wrote to make it into CUSTOM IP below.
// UART_TX
Baud Rate == 1152000, FPGA clock = 50MhzClock per Byte(CPB) = 1152000/20ns = 434*//////////////////////////////module UART_TX(input clk,reset_n ,input [7:0] tx_din ,input we ,output done ,output tx_dout);parameter [3:0]IDLE = 0,START = 1,DATA0 = 2,DATA1 = 3,DATA2 = 4,DATA3 = 5,DATA4 = 6,DATA5 = 7,DATA6 = 8,DATA7 = 9,STOP0 = 10,STOP1 = 11;localparam CPB = 434;////// wire , reg declarationreg [3:0] state,next_state ;reg [9:0] cnt ;reg dout_reg ;wire [7:0] din_reg ;assign din_reg = tx_din ;////////////////////////////////////////state transition logicalways @(cnt,we) beginnext_state = IDLE;case(state)IDLE : next_state = (we & cnt == CPB - 1) ? START : IDLE;START : next_state = (we & cnt == CPB - 1) ? DATA0 : START;DATA0 : next_state = (we & cnt == CPB - 1) ? DATA1 : DATA0;DATA1 : next_state = (we & cnt == CPB - 1) ? DATA2 : DATA1;DATA2 : next_state = (we & cnt == CPB - 1) ? DATA3 : DATA2;DATA3 : next_state = (we & cnt == CPB - 1) ? DATA4 : DATA3;DATA4 : next_state = (we & cnt == CPB - 1) ? DATA5 : DATA4;DATA5 : next_state = (we & cnt == CPB - 1) ? DATA6 : DATA5;DATA6 : next_state = (we & cnt == CPB - 1) ? DATA7 : DATA6;DATA7 : next_state = (we & cnt == CPB - 1) ? STOP0 : DATA7;STOP0 : next_state = (we & cnt == CPB - 1) ? STOP1 : STOP0;STOP1 : next_state = (we & cnt == CPB - 1) ? IDLE : STOP1;endcaseend//state sequantial logicalways @(posedge clk, negedge reset_n) beginif(!reset_n) state <= IDLE;else state <= next_state;end//i_clk counteralways @(posedge clk, negedge reset_n) beginif(!reset_n) cnt <= 10'd0;else beginif(state != next_state) cnt <= 10'd0;else cnt <= cnt + 10'd1;endend//output logicalways @(*) begindout_reg = 1;case(state)IDLE : dout_reg = 1;START : dout_reg = 0;DATA0 : dout_reg = din_reg[0];DATA1 : dout_reg = din_reg[1];DATA2 : dout_reg = din_reg[2];DATA3 : dout_reg = din_reg[3];DATA4 : dout_reg = din_reg[4];DATA5 : dout_reg = din_reg[5];DATA6 : dout_reg = din_reg[6];DATA7 : dout_reg = din_reg[7];STOP0 : dout_reg = 1;STOP1 : dout_reg = 1;endcaseendassign tx_dout = dout_reg;assign done = (state == STOP1);endmodule// HDL CODE FOR USING CUSTOM IP
module TX_IP(input clk,reset_n,output done,q_ex);Qsys_default u0 (.clk_clk (clk), // clk.clk.reset_reset_n (reset_n), // reset.reset_n.tx_dout_qsys_0_conduit_end_export (q_ex), // tx_dout_qsys_0_conduit_end.export.done_0_conduit_end_1_export (done) // done_0_conduit_end_1.export);endmodule////////////////////////////////////////////////////////////
Thank you again for your dedication.
Thanks to this community, I was able to grow quickly
