15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years agoThe pio data register access is always 32 bits. If your PIO is 5 bits wide, then the 27 most significant bits will be 0 when you read and ignored when you write. Just use the low 5 bits.
