15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years agoregister 0 will give you back a number that represents your PIO lines if the core is configured as input lines. Please have a look at the documentation chapter 10, this is covered pretty well.
http://www.altera.com/literature/ug/ug_embedded_ip.pdf (http://www.altera.com/literature/ug/ug_embedded_ip.pdf)
