15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years agoIn order to read PIO data, with or without DMA, you need a single address, namely your PIO base address. The fifo will automatically pop a single data word on every access.
Using DMA you'll setup the read from this constant address (i.e. RCON bit for DMA controller core, not SGDMA) and the write (with WCON=0) to the buffer you choose, SRAM, DDR2, onchip RAM or whatever. For SGDMA core you have the increment field in dma descriptor insted of RCON/WCON control bits. I think it is possible to dma directly from PIO to TSE but this strongly depends on the ethernet protocol you need to use.
