15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years ago@dsl
--- Quote Start --- An embedded ethernet/TCP stack shouldn't necessarily require interrupts --- Quote End --- Sorry, you are right. I actually meant Nichestack uses two high priority TASKS not interrupts. This is valid in the standard way of operation based on Micrium RTOS, unless you use superloop mode. Anyway what I said still applies: the OS scheduler interrupt periodically takes control over your polling loop and delays your samples by a possibly indeterminate amount of time. Cris
