15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years agoI use Nichestack, too. It uses two high priority interrupts to manage ethernet rx and protocol: this is leading to the delay you are experiencing.
Nichestack also includes some critical pieces of code where isr are temporarily disabled, so you can't attain such a precise timing as you require, even if your sampling is made through a highest priority timer interrupt. the only way to perform precise sampling at f>100kHz is to make it with hardware, dma or similar.
