15 years agoIORD_ALTERA_AVALON_PIO_DATA to slow?
Hi, I'm trying to capture samples from an A/D Converter and streaming them onto a PC via an ethernet connection. I've extended the triple speed ethernet design example from the Nios II v9.1 instal...
15 years agoIf you are trying to check your ADC I'd definitely read a block to an array, then copy that out somehow.
The sprintf() is probably several 100 clocks - if not several 1000, especially if you haven't ensured that everything is compiled with -O2 or -O3. The IORW() itself is probably 2 (depends on the number of wait states in your ADC slave) .
