13 years ago
IORD_ALTERA_AVALON_PIO_DATA execution speed
Is there a faster way to read a pin than using the IORD_ALTERA_AVALON_PIO_DATA macro?
I'm finding the code below is running quite slow, but by removing the second condition (i.e. reducing the number of IORD_ALTERA_AVALON_PIO_DATA commands) it runs significantly faster, almost an order of magnitude.
Is there any overhead in this macro that I can get around by doing something more direct? Looking through the header files I couldn't see anything, but I thought it was worth asking.
Bert
if ((IORD_ALTERA_AVALON_PIO_DATA(PIO_CONTROL_IN_BASE) == 0x02) || (IORD_ALTERA_AVALON_PIO_DATA(PIO_CONTROL_IN_BASE) == 0x03)) {
    sample_array = IORD_ALTERA_AVALON_PIO_DATA(PIO_ADC_DATA_BASE);
    i++;
    Actually for something like this I would rather use a DMA to periodically read the AD data from the converter and write it directly to memory. You could then raise an interrupt once a buffer is full and let the CPU handle the Ethernet encapsulation.
