15 years agoInterval timer
Is it necessary to have an interval timer in your sopc design for a microc/os-ii project to work? what would happen if you dont put an interval timer.. in my bsp it shows system clock timer as none. ...
15 years agoI didn't look at the OS code in detail but I doubt the scheduler will work correctly without a timer. You may have a problem when you start running several threads simultaneously.
