14 years ago
Interval Timer Problem
I got a system with an interval timer. Now I want to use it to to count how long the time is between two positiv flanks. But the counter won't start.
My code:
  int count_timeH=0;
    int count_timeL=0;
    IOWR_ALTERA_AVALON_TIMER_PERIODH(SYS_CLK_TIMER_BASE,0x0);
    IOWR_ALTERA_AVALON_TIMER_PERIODL(SYS_CLK_TIMER_BASE,0x0);
    //start the counter
    IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE,0x04);
    printf("Control : %x\n",IORD_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE));
    printf("Status: %x\n", IORD_ALTERA_AVALON_TIMER_STATUS(SYS_CLK_TIMER_BASE));
    count_timeL= IORD_ALTERA_AVALON_TIMER_SNAPL(SYS_CLK_TIMER_BASE);
    printf("SnapL : %d\n", count_timeL);
    count_timeH= IORD_ALTERA_AVALON_TIMER_SNAPH(SYS_CLK_TIMER_BASE);
    printf("SnapH : %d\n", count_timeH);
    //wait till the FAD gives back the right frequency
    int j;
    for ( j = 0; j < 2; ++j) {
        push_The_Button(FAD_CLOCK_BASE);
        printf("Flanke Nummer %d \n", j);
    //stop the counter
    IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE,0x08);
And the registers contents are:
Control : 0
Status: 1
SnapL : 9216
SnapH : 3286019
Knopf drücken!
Flanke Nummer 0
Knopf drücken!
Flanke Nummer 1
Status: 0
SnapL : 9216
SnapH : 3154947
So how you can see in the code I just start counting but the control register still is "0". Why the content doesn't cange?
And from which registers I can read my countsize?
Thanks in advance for your help!
    Hi cris,
    I'm using it as a cycle counter.
    So I need to change the timeout period to 1sec instead of 1 msec if I want to measure a time round about 0.0008 sec. I also want to measure it exactly as possible.
    Thanks is advance for your answer!
    --- Quote Start ---
    --- Quote End ---
    You definitely need a timeout period larger than the measured time.
    As I said above, if your timer is dedicated to the measuring task and doesn't serve other functions or peripherals, you can operate it freely.
    So, I suggest this:
    - set timeout period larger than the maximum expected interval to be measured
    - timer initialized in stopped status
    - reset and start the timer when you start your measure,
    - stop the timer at the end of measure
    - read the duration
    --- Quote Start ---
    --- Quote End ---
    This greatly depends on your application, namely how you perform the measurement:
    - poll a PIO or any other condition and start/stop/read the timer: poor precision, dependent from your polling rate, unless you can afford using the 100% of cpu time for the polling loop and don't execute any other task
    - use a irq triggered by start/stop conditions: common solution for greater system effinciency and good precision in the us range
    - use a hardware counter solution which automatically identifies start/end conditions and places the measurement in a register which you can read without effort: maximum precision at the expense of a slight increment in hw complexity (fpga resource usage)
    Hi cris,
    thanks for the help, now it works! I just setup the timeout period to "1sec" and changed a little bit of my code:
    --- Quote Start ---
    double count_The_Frequency()
    double total_time_steps=0;
    double calculated_time=0;
    double calculated_frequency=0;
    alt_u32 count_step_1=0x0;
    alt_u32 count_step_2=0x0;
    int a=0;
    //start address of the counter
    IOWR_ALTERA_AVALON_TIMER_PERIODH(SYS_CLK_TIMER_BASE,0xFFFF);
    IOWR_ALTERA_AVALON_TIMER_PERIODL(SYS_CLK_TIMER_BASE,0xFFFF);
    IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE,ALTERA_AVALON_TIMER_CONTROL_STOP_MSK);
    //total_time is in seconds but is measured in ms
    //the range depends on the frequency you want to have
    //while((total_time<=10) & (total_time>=5)){ //while((total_time<=0.001) & (total_time>=0.00065)){
    //by writing to the snapregister you get the data from the counter
    IOWR_ALTERA_AVALON_TIMER_SNAPL(SYS_CLK_TIMER_BASE,0x1);
    IOWR_ALTERA_AVALON_TIMER_SNAPH(SYS_CLK_TIMER_BASE,0x2);
    //start the counter
    IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE,0x06);
    int j;
    a=a+1;
    if(a==1){
    count_step_1 = IORD_ALTERA_AVALON_TIMER_SNAPH(SYS_CLK_TIMER_BASE)<<16;
    count_step_1 =count_step_1|(IORD_ALTERA_AVALON_TIMER_SNAPL(SYS_CLK_TIMER_BASE));
    if(a==2){
    count_step_2 = IORD_ALTERA_AVALON_TIMER_SNAPH(SYS_CLK_TIMER_BASE)<<16;
    count_step_2 =count_step_2|(IORD_ALTERA_AVALON_TIMER_SNAPL(SYS_CLK_TIMER_BASE));
    //printf("SnapH : %e\n", (double)IORD_ALTERA_AVALON_TIMER_SNAPH(SYS_CLK_TIMER_BASE));
    //stop the counter
    IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_CLK_TIMER_BASE,0x8);
    //printf("1; %x\n", count_step_1);
    // printf("2: %x \n", count_step_2);
    total_time_steps= (count_step_1-count_step_2);
    calculated_time= total_time_steps/(50000000);
    calculated_frequency=1/calculated_time;
    // printf("Frequenz: %e\n", calculated_frequency);
    return calculated_frequency;
    --- Quote End ---
