14 years agoInterval Timer Problem
Hi, I got a system with an interval timer. Now I want to use it to to count how long the time is between two positiv flanks. But the counter won't start. My code: int count_timeH=0...
14 years ago --- Quote Start --- I'm using it as a cycle counter. So I need to change the timeout period to 1sec instead of 1 msec if I want to measure a time round about 0.0008 sec. --- Quote End --- You definitely need a timeout period larger than the measured time. As I said above, if your timer is dedicated to the measuring task and doesn't serve other functions or peripherals, you can operate it freely. So, I suggest this: - set timeout period larger than the maximum expected interval to be measured - timer initialized in stopped status - reset and start the timer when you start your measure, - stop the timer at the end of measure - read the duration --- Quote Start --- I also want to measure it exactly as possible. --- Quote End --- This greatly depends on your application, namely how you perform the measurement: - poll a PIO or any other condition and start/stop/read the timer: poor precision, dependent from your polling rate, unless you can afford using the 100% of cpu time for the polling loop and don't execute any other task - use a irq triggered by start/stop conditions: common solution for greater system effinciency and good precision in the us range - use a hardware counter solution which automatically identifies start/end conditions and places the measurement in a register which you can read without effort: maximum precision at the expense of a slight increment in hw complexity (fpga resource usage)
