13 years agoInterval timer problem
Hello. I’ve got a problem with simple interrupt from interval timer in uC/OS-II System frequency is 75Mhz. There are PIO and timer. It makes strobe. Duration 10 ms. Here it is:
// glob...
13 years agoI do not care about the boot time of my board, and the duration of the execution of other instructions. But at a certain moment NIOS' application must produce a series of strobes with various durations. But it does not produce them because timer init instructions get stuck in layers of HAL uC. I asked how to speed up their execution. And that’s all.
It’s hard to realize this staff on FPGA logic because it works closely to other subprograms. I got that there is no any settings in bsp property to make writing to an interrupt register exec faster. I understand that I should work with timer like with pll. I should configure timer to produce interruptions at a fixed period, and count interruptions to produce strobes with longer duration. Thank you.
