15 years agointerrupt problem
Hi all,
i've modified the DE2 Media Computer demo, in order to register\play 2 different messages. It works fine. Then i've tried to add a blinking led adding an interval timer(period 1 sec, simple periodic interrupt) in my SOPC, but i've some problem with it: - it blinks, but faster than 1 sec, and every 3 blinks, 1 is faster than the others - when i press a button, it stops blinking until i relese the button I supposed that it was related with the IRQ number in SOPC builder, and i changed it to 0 for my interval timer...anything changed... my code is:# ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
static void alt_avalon_timer_sc_irq (void* base)# else
static void alt_avalon_timer_sc_irq (void* base, alt_u32 id)# endif
alt_irq_context cpu_sr;
// clear the interrupt
IOWR_ALTERA_AVALON_TIMER_STATUS (base, 0);
illu_led = !illu_led; //switch a flag
* Dummy read to ensure IRQ is negated before the ISR returns.
* The control register is read because reading the status
* register has side-effects per the register map documentation.
IORD_ALTERA_AVALON_TIMER_CONTROL (base);
// ALT_LOG - see altera_hal/HAL/inc/sys/alt_log_printf.h
// ALT_LOG_SYS_CLK_HEARTBEAT();
* Notify the system of a clock tick. disable interrupts
* during this time to safely support ISR preemption
cpu_sr = alt_irq_disable_all();
alt_tick ();
alt_irq_enable_all(cpu_sr);
void alt_avalon_timer_sc_init (void* base, alt_u32 irq_controller_id,
alt_u32 irq, alt_u32 freq)
// set the system clock frequency
alt_sysclk_init (freq);
// set to free running mode
IOWR_ALTERA_AVALON_TIMER_CONTROL (base,
ALTERA_AVALON_TIMER_CONTROL_ITO_MSK |
ALTERA_AVALON_TIMER_CONTROL_CONT_MSK |
ALTERA_AVALON_TIMER_CONTROL_START_MSK);
// register the interrupt handler, and enable the interrupt
alt_ic_isr_register(irq_controller_id, irq, alt_avalon_timer_sc_irq,
base, NULL);# else
alt_irq_register (irq, base, alt_avalon_timer_sc_irq);# endif
}and in my main function, inside while(1):
IOWR_ALT_UP_PARALLEL_PORT_DATA( RED_LEDS_BASE, illu_led); someone can help?No RepliesBe the first to reply
