12 years agoInterrupt on my radar application - what have I been programming ?
Dear Forum users,
I implemented with verilog a simple 32 bit wide COUNTER. Then I read the counter out with Nios and I implemented on my radar application two switches - one switch for starting the radar pulse and one switch for displaying the result on the RS232. Now the code it functions but I do not know what I have been implementing with version 9.1. The code will look as follows: //PAVLE DUKANOVIC //www.dukelanovic.com //Neckarrems,19.10.2014 // //RS232 COMMUNICATIONS // # include<stdio.h># include<string.h># include "altera_avalon_pio_regs.h" # include "alt_types.h"# include "unistd.h" # include "system.h"# include "sys/alt_irq.h" # define seg *(volatile unsigned char *) SEG_BASE # define bit *(volatile unsigned char *) BIT_BASE # define RESET *(volatile unsigned char *) RESET_BASE# define TRIG *(volatile unsigned char *) TRIG_BASE# define COUNTER *(volatile alt_u32 *) COUNTER_BASE# define START *(volatile alt_u32 *) START_BASE const alt_u8 duan[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; // 0 1 2 3 4 5 6 7 8 9 alt_u8 num[8] = {0,0,0,0,0,0,0,0}; alt_u8 number[8]; alt_u32 n = 0; alt_u8 key_flag; alt_u8 key_flag1; volatile int edge_capture; void key_ISR(void* context, alt_u32 id) { IOWR_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE,0); IORD_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE); key_flag = 1; } void key3_ISR(void* context, alt_u32 id) { IOWR_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE,0); IORD_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE); key_flag1 = 1; } void key_Init() { IOWR_ALTERA_AVALON_PIO_IRQ_MASK(START_BASE,0xF); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE,0x0); alt_irq_register(START_IRQ,NULL,key_ISR); //START_IRQ 3 } void key3_Init() { IOWR_ALTERA_AVALON_PIO_IRQ_MASK(K3_BASE,0xF); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(K3_BASE,0x0); alt_irq_register(K3_IRQ,NULL,key3_ISR); //START_IRQ 3 } // This function will display 8 Numbers void display(alt_u32 i) { alt_u8 j; num[0] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)%10; num[1] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)/10; num[2] = (((((i % 10000000)%1000000)%100000)%10000)%1000)/100; num[3] = ((((i % 10000000)%1000000)%100000)%10000)/1000; num[4] = (((i % 10000000)%1000000)%100000)/10000; num[5] = ((i % 10000000)%1000000)/100000; num[6] = (i % 10000000)/1000000; num[7] = i / 10000000; for(j=0; j<8; j++) { bit = ~(0x01 << j); seg = duan[num[j]]; // here the display is switched on usleep(100); } number[7] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)%10+0x30; number[6] = ((((((i % 10000000)%1000000)%100000)%10000)%1000)%100)/10+0x30; number[5] = (((((i % 10000000)%1000000)%100000)%10000)%1000)/100+0x30; number[4] = ((((i % 10000000)%1000000)%100000)%10000)/1000+0x30; number[3] = (((i % 10000000)%1000000)%100000)/10000+0x30; number[2] = ((i % 10000000)%1000000)/100000+0x30; number[1] = (i % 10000000)/1000000+0x30; number[0] = i / 10000000+0x30; } int main () { char* msg = "M01 "; FILE* fp; key_Init(); key3_Init(); printf("RS232 DEMO : \n"); fp = fopen (UART_NAME, "r+"); // here we initialize the RS232 port RESET = 1; TRIG =1; while(1){ n = COUNTER; display(n); usleep(100); if(key_flag){ TRIG = 0; usleep(10); fwrite (msg, strlen (msg), 1, fp); // here we write on the RS232 usleep(40000); key_flag = 0; TRIG = 1; } if(key_flag1){ fwrite (number, strlen (number), 1, fp); // here we write on the RS232 key_flag1 = 0; } } return 0; } Can you tell me where I can find a good reference about programming and handling interrupts? What have I been doing with the initialisation of my interrupt? void key_Init() { IOWR_ALTERA_AVALON_PIO_IRQ_MASK(START_BASE,0xF); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(START_BASE,0x0); alt_irq_register(START_IRQ,NULL,key_ISR); //START_IRQ 3 } What do those commands mean ? Please help me.2 Replies
This document has a C code explaining it. The content is present on pg 8-15.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/nios2/n2sw_nii5v2.pdf I hope you enabled interrupts while creating your system in qsys and did give the right priority to the different components.
