15 years agoInterNiche Stack select POSIX compliant?
I'm trying to modifying the SimpleSocketServer example. There is a select system call which operates on sockets. I also passed it stdin which appeared appeared to work but I am getting some strange b...
15 years agoIIRC you are right and the select call is specific to the Interniche stack. If you want to listen to both stdin and a socket, it may be easier to do it from two different threads.
