15 years ago
internal compiler error in Net-SNMP compilation
Did anyone run into that ? (build env is latest from GIT)
../../net-snmp-5.2.1/snmplib/parse.c: In function 'unload_all_mibs':
../../net-snmp-5.2.1/snmplib/parse.c:4057: error: unrecognizable insn:
(insn 217 216 218 23 ../../net-snmp-5.2.1/snmplib/parse.c:3994 (set (reg:SI 50 [ D.13259 ])
(plus:SI (reg:SI 120)
(const_int 114660 [0x1bfe4]))) -1 (nil)
(expr_list:REG_EQUAL (const:SI (plus:SI (symbol_ref:SI ("tclist") <var_decl 0x40324d68 tclist>)
(nil)))
../../net-snmp-5.2.1/snmplib/parse.c:4057: internal compiler error: in extract_insn, at recog.c:2093
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
make[5]: *** [parse.lo] Error 1
any suggestion on how to continue from here ? if I unselect net-snmp and delete all build related directories and reselct it with different options set it sometimes work.. there is something inconsistent with building that application ...
Lior
    --- Quote Start ---
    I tested to compile 'net-snmp-5.2.1', and in may case, it succeeded. My compiler version is
    nios2-wrs-linux-gnu-gcc (Wind River Linux Sourcery G++ 4.1-176) 4.1.2
    Copyright (C) 2006 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    I did it as
    Kazu.
    --- Quote End ---
    Hi, Mr Kazu
    Could you do me a favor?
    Why did I Build the gcc4 toolchain with the method of this url http://www.alterawiki.com/wiki/build_the_gcc4_toolchain
    I can't find neither the nios2-wrs-linux-gnu file nor folder,even not use the command 'nios2-wrs-linux-gnu-gcc -v'
    # cd /opt/nios2gcc4/
    # ls
    build.sh  install  logs  obj  pkg  src
    # cd /opt/nios2gcc4/src/
    # ls
    binutils-2.17.50  gcc-4.1  glibc-2.5            glibc-ports-2.5
    expat-mirror      gdb-wrs  glibc_localedef-2.5  linux-2.6.21-wrs-nios2
    # ls
    0001-kbuild-fix-C-libary-confusion-in-unifdef.c-due-to-g.patch  lib
    arch                                                            ltt
    block                                                           MAINTAINERS
    COPYING                                                         Makefile
    CREDITS                                                         mm
    crypto                                                          net
    Documentation                                                   README
    drivers                                                         REPORTING-BUGS
    fs                                                              scripts
    include                                                         security
    init                                                            sound
    ipc                                                             usr
    Kbuild                                                          WRLINUX_PATCHES
    kernel
    So, I can't make EP3C120_config with the nios2-wrs-linux-gnu-gcc.
    # make EP3C120_config
    make: nios2-wrs-linux-gnu-gcc&#65306;command not found
    Generating include/autoconf.mk.dep
    /bin/sh: line 3: nios2-wrs-linux-gnu-gcc: command not found
    Configuring for EP3C120 board...
    Thanks!
    --- Quote Start ---
    --- Quote End ---
    ?? The word "wrs" means the version which is compiled by 'Wind River Systems". If you build tools from these sources, the compiler's names will be "nios2-linux-gnu-***".
    And you may also get the compiled tools from the ftp site,
    ftp://sopc.et.ntust.edu.tw/pub/gnutools/
    Kazu
    Hi, How did you build this
    tools&#65311; Could you give me some a clue ?
    Although I have build these tools,but the toolchain-build still remind me
    /bin/sh: nios2-wrs-linux-gnu-gcc: command not found
    Which step do I lost ?
    # nios2-linux-gnu-gcc -vUsing built-in specs.
    Target: nios2-linux-gnu
    Configured with: /opt/nios2gcc4/src/gcc-4.1/configure --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=nios2-linux-gnu --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --enable-languages=c,c++ --enable-shared --enable-symvers=gnu --enable-__cxa_atexit --disable-nls --prefix=/opt/nios2 --with-sysroot=/opt/nios2/nios2-linux-gnu/libc --with-build-sysroot=/opt/nios2gcc4/install/nios2-linux-gnu/libc --disable-libgomp --enable-poison-system-directories
    Thread model: posix
    gcc version 4.1.2
    # nios2-linux-uclibc-gcc -v
    Reading specs from /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/specs
    Configured with: /root/buildroot/toolchain_build_nios2/gcc-3.4.6/configure --prefix=/opt/nios2 --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=nios2-linux-uclibc --enable-languages=c,c++ --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-shared --disable-nls --enable-threads --enable-multilib
    Thread model: posix
    gcc version 3.4.6
    # nios2-linux-gcc -v
    Thread model: posix
    gcc version 3.4.6
    Thanks!
