15 years agoInterfacing with narrower width of slave
Hi I have a question regarding to interfacing with narrower or wider width of slave. As we know, our Nios II is 32-bit width. To perform a read/write to a slave, says a 16-bit memory, how should this...
15 years agoThanks dsl for your quick answer. Do you mean I'm going to use IOWR_32DIRECT(_BASE, 0, 0x12345678);?
In fact, I have another project which needs to use my own custom memory controller. Unfortunately, it does not have byte-enable signal. Do you have any advice for me? Thanks again.
