17 years ago
interconnection between uCLinux and Windows by USB gadget
I've already read some bad news about the chance to interconnect a Linux system and a Windows system using the USB gadgets. Below you can find some tests done to verify the current functionality of both device and driver. Seeing that in linux the game works, I suspect that the generic windows driver is not the best one can find. In a mailing list I've found the news (in January and June) about the absence of a good driver for Windows. Anyone has recently tested a good driver for windows that makes USB gadgets to be correctly identified? I mean every kind of: open souce, freeware, proprietary, pay-per-use, licensed under fee payment.... any suggestion is accepted, even the suggestion for other tests.
TESTS PASSED:
- usb serial gadget to Linux pc: sending and receiving strings with kermit on PC and using echo and cat on our board
- usb serial gadget to Linux pc: with an application of ours (developed for testing devices) which sets termios, sends and receive characters between the two endpoints and release some stats. No character lost.
- usb serial gadget to Linux pc: file excange after connecting them between PPP over ttyGS and ttyACM
- usb ethernet gadget to linux pc: connecting, ping (with low latency), telnet, file exchange using ftpget and ftpput
- usb compostie ( CDC+ACM): connection, some pings, file exchanges, telnet
- usb serial to linux pc: using an application with a custom protocol, the first handshake always fails but then the other exchanges works as good as on the rs232 serial
FAILED TESTS:
- usb ethernet to Windows pc: after installing the .inf file found in linux documentation in device manger I can see an RNDIS device but with the following error: This device cannot start CODE 10. Microsoft throubleshoot tells about unistalling and reinstalling, plugging and unplugging...
- usb serial to Windows pc: exchange strings using hyperterminal on windows and cat end echo on our board
- usb serial to Windows pc: PPP between the two systems goes up and it is possible to open a telnet or to ping but it has a very burstiness habit in the latency. We observed that pings goes slow if our embedded system pings windows (>1000 ms) but it falls down to 7 ms if windows is pinging the system (eventually if both are pinging each other). The telnet over this PPP connection has a very long latency for echoing the characters and even the execution of a simple command (like ls) takes a while before getting the results (which come alltogheter fastly).
EQUIPEMENT FOR TESTS:
- Windows XP Pro SP3
- Linux openSuse 10.11
- Embedded system: custom board with NXP ISP1161X controller. uClinux released in August with kernel 2.6.30
    I had no problems with a serial USB device I made using a PIC. Same needs just a text file as USB "driver!" on the PC to make the standard serial driver accept the device ID.
    Why should using a Linux/NIOS system as USB device offer more problems ?
    -Michael
    --- Quote Start ---
    -Michael
    --- Quote End ---
    this puzzle is the thing that made me post here... I verified this to work on linux, I then noticed the problem on windows. I searched the internet and found some mailing lists reporting things like this:
    http://markmail.org/message/rd6cbsumosz6zdht
    which make me thinks I'm not the only dealing with this problems.
    Could you tell me how to config the kernel to finish that usb serial gadget to Linux pc?
    I missed to see your post. I am replying quite an year later... I do not know if you still have problems.
