8 years agoIntel HLS example reports
I am new to the concept of HLS. I am using Intel HLS and going to start with the examples that come with the installation of Quartus prime edition. Can anyone of you share the successful project report files generated after testing any of those examples ? The examples are Counter, image_downsample,interp_decim_filter,QRD and YUV2RGB. Anyone who has tried with one of these examples, it would be great if you can attach the project files post synthesis in this thread .... Will be thankful27 Replies
dear Anand,
waiting for your helpful reply... thanks - Altera_Forum
1.What for the below lines are used and where is the function? --- Quote Start --- //call reference function ref_sol(a, b, &ref_res); --- Quote End --- 2.How "check results" session of code works? With few modification I have compiled the code.#include "HLS/hls.h" # include <stdio.h> # include "HLS/ac_int.h" # include "HLS/ac_fixed.h" # include "HLS/extendedmath.h" # include "HLS/math.h" using namespace ihc; component void sol (int a, int b, int *dout) { int i; int acc= 0; int a_reg, b_reg, sub, sub2; //int N=10; for(i=0; i<sizeof(a); i++) { # pragma HLS PIPELINE II=1 a_reg = a; b_reg = b; sub = a_reg - b_reg; sub2 = sub*sub; acc += sub2; } *dout = acc; } int main(void) { int i, k, cnt; int ret_val = 0; int N=10; int a, b; int aa, bb; long long int ref_res; int res; cnt = 0; //create random data for(i=0; i<N; i++) { a = rand() % (1024*16); b = rand() % (1024*16); aa = (int) a; bb = (int) b; } //call design Under Test sol( aa, bb, &res); return ret_val; }
let me know if this has helped resolve the issue you are facing or if you need any further assistance. please open a new thread if question does not matches with the thread title Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)VisualStudio's link.exe is not on the path. Guessing its location. VS100COMNTOOLS environment variable is set to c:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools\. Looks like you have VisualStudio2010 installed. Using it. Setting environment for using Microsoft Visual Studio 2010 x64 tools. Adding c:\intelFPGA_pro\17.1\hls\bin to PATH Adding c:\intelFPGA_pro\17.1\hls\host\windows64\bin to PATH c:\intelFPGA_pro\17.1\hls>cd c:\Users\anandr1x\Desktop\hls\u The system cannot find the path specified. c:\intelFPGA_pro\17.1\hls>cd c:\Users\anandr1x\Desktop\hls\userhls c:\Users\x\Desktop\hls\userhls>build.bat test-x86-64 i++ -march=x86-64 sol.cpp -o test-x86-64.exe sol.cpp:17:18: warning: sizeof on array function parameter will return size of 'int *' instead of 'int ' for(i=0; i<sizeof(a); i++) ^ sol.cpp:11:25: note: declared here component void sol (int a, int b, int *dout) ^ 1 warning generated. Run test-x86-64.exe to execute the test. c:\Users\x\Desktop\hls\userhls>build.bat test-fpga i++ -march=Arria10 sol.cpp -o test-fpga.exe sol.cpp:17:18: warning: sizeof on array function parameter will return size of 'int *' instead of 'int ' for(i=0; i<sizeof(a); i++) ^ sol.cpp:11:25: note: declared here component void sol (int a, int b, int *dout) ^ 1 warning generated. sol.cpp:17:18: warning: sizeof on array function parameter will return size of 'int *' instead of 'int ' for(i=0; i<sizeof(a); i++) ^ sol.cpp:11:25: note: declared here component void sol (int a, int b, int *dout) ^ 1 warning generated. Error: Cannot remove ./test-fpga.prj: Can't remove file ./test-fpga.prj/quartus: Permission denied Run test-fpga.exe to execute the test. - Altera_Forum
Dear Anand,
thanks for your reply....sorry for the confusion and messing things up....I have posted three codes below under headings SOURCE file, HEADER and TEST BENCH. This will definitely give you the whole idea. Regarding your question ".What for the below lines are used and where is the function? " please check the third code under TEST BENCH. Regarding your question "How check results session of code works?" also please check the third code under TEST BENCH. SOURCE file # include "../src/diff_sq_acc.h" void diff_sq_acc(din_t a[N], din_t b[N], dout_t *dout) { unsigned char i; float acc= 0; float a_reg, b_reg, sub, sub2; diff_sq_acc_label0:for(i=0; i<N; i++) { a_reg = a;b_reg = b; sub = a_reg - b_reg; sub2 = sub*sub; acc += sub2; } *dout = acc; } HEADER # ifndef H_SQRT_ACC_H# define H_SQRT_ACC_H # include <stdlib.h># include "ap_int.h" typedef float din_t; typedef float dout_t; # define N 100 void diff_sq_acc(din_t a[N], din_t b[N], dout_t *dout); # endif //#ifndef H_SQRT_ACC_H TEST BENCH # include <stdio.h># include "../src/diff_sq_acc.h" void ref_diff_sq_acc(int a[N], int b[N], long long int *dout) { int i; long long int acc = 0; int diff; long long int diff2; for(i=0; i<N; i++) { diff = a-b; diff2 = (long long int) diff * (long long int) diff; acc += diff2; } *dout = acc; } int main(void) { int i, k, cnt; int ret_val = 0; int a[N], b[N]; din_t aa[N], bb[N]; long long int ref_res; dout_t res; cnt = 0; for (k=0; k<10; k++) { //create random data for(i=0; i<N; i++) { a = rand() % (1024*16);
b = rand() % (1024*16); aa = (din_t) a; bb = (din_t) b; } //call reference function ref_diff_sq_acc(a, b, &ref_res); //call design Under Test diff_sq_acc( aa, bb, &res); //check results printf("got %lld expected %lld\n", (long long int) res.to_double(), (long long int) ref_res); if ( (ref_res - (long long int) res) !=0 ) cnt++; } if (cnt>0) { printf("TEST FAILED: %d errors\n", cnt); ret_val = 1; } else { printf("TEST SUCCESS!\n"); ret_val = 0; } return ret_val; }
Dear Anand,
Can you please attach your whole code with the executable and reports in this thread ? That would be really helpful.... - Altera_Forum
Refer the below link https://drive.google.com/open?id=1bai8bhwpl3rzytqjqkhcdmiecf5ftrju Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation - Altera_Forum
Dear Anand,
thanks for the reply....And if I have to use your code for float and fixed data type inputs then ? Basically just to compare the results for fixed and float inputs....in first case if i use it for fixed data input and in second case if I use for float input ? Can you please help me with these two data types in the same code.... ? - Altera_Forum
And one more question.....
If I use the data type float in the same code, please recommend me what should be the exact representation of ac_fixed <W,I> in terms of W and I if I want to use the exact code for fixed data type and later compare the results of float and fixed data type. Waiting for your valuable reply....so far you have been a great help. - Altera_Forum
Dear Anand
While going through AC data types used by Intel HLS, I have written the same code in terms of ac_fixed data types below. I will be really grateful if you can run and synthesize at your end. Thanks in advance......you have been so far very helpful..... void diff_sq_acc( ac_ufixed<11,1> a[N], ac_ufixed<11,1> b[N], ac_ufixed<28,8> *dout) { unsigned char i; ac_ufixed<28,8> acc= 0; ac_ufixed<11,1> a_reg, b_reg; ac_fixed<12,2> sub; ac_ufixed<21,1> sub2 ; for(i=0; i<N; i++) { # pragma HLS PIPELINE II=1 a_reg = a;b_reg = b; sub = a_reg - b_reg; sub2 = sub*sub; acc += sub2; } *dout = acc; }
Dear Anand,
as always waiting for your valuable reply and help.... thanks - Altera_Forum
1.To get the difference between float and fixed data type you can use the tutorials the installation directory. "..\intelFPGA_pro\17.1\hls\examples\tutorials" 2.Create simple project like multiplication to understand the difference.
3.What is the error you are getting from your code, can screenshot and post it? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)#include "HLS/hls.h"# include <stdio.h># include "HLS/ac_int.h"# include "HLS/ac_fixed.h"# include "HLS/extendedmath.h"# include "HLS/math.h" typedef ac_int<8, false> fixed_8_t; typedef ac_int<16, false> fixed_16_t;# define N 2 component void dut(fixed_8_t a, fixed_8_t b, fixed_8_t *dout) { unsigned int i; fixed_16_t acc= 0; fixed_8_t a_reg, b_reg, sub; fixed_16_t sub2; for(i=0; i<N; i++) { a_reg = a; b_reg = b; sub = a_reg - b_reg; sub2 = sub*sub; acc += sub2; } *dout = acc; } int main() { fixed_8_t z; fixed_16_t ip = &z; fixed_8_t x={128,128}; fixed_8_t y={128,128}; dut(x,y,&z); printf("%d \n",*ip); getchar(); return 0; }
