8 years agoIntel HLS example reports
Hello, I am new to the concept of HLS. I am using Intel HLS and going to start with the examples that come with the installation of Quartus prime edition. Can anyone of you share the succe...
8 years agoDear Anand,
thanks for the reply....And if I have to use your code for float and fixed data type inputs then ? Basically just to compare the results for fixed and float inputs....in first case if i use it for fixed data input and in second case if I use for float input ? Can you please help me with these two data types in the same code.... ?
