intel Cyclone 10 GX NIOS-II I2C Slave problem
- 3 years ago
We do not have an I2C slave IP unfortunately, but with the I2C Host IP in your design, other peripherals connected to the I2C are considered as the slaves already.
Maybe you could try to determine the master and slave by determining what devices will be connected to the I2C bus, which will be the master and what is the use case.
Hope this could clear your doubts. Thank you.
Kelly
Kelly
- ENG19993 years ago
Hi Kelly,
Thanks for your reply. I really appreciate it. ^_^
