14 years ago
Install Quartus 12.0 in the 64bit of Ubuntu 12.04
1.Download offline version install file and unzip it
https://www.altera.com/download/software/quartus-ii-we
2.Run command
...<your_folder>/12.0_178_quartus_free_linux/altera_installer/bin/altera_installer_gui --gui
3.Select ...<your_folder>/12.0_178_quartus_free_linux/
and Select install target folder (where you want file installed)
4.Manually install 64bit part
cd to ...<your_folder>/12.0_178_quartus_free_linux/linux_installer/quartus_free_64bit/
run install
type your install folder path
choose "n" for not delete installed files
5.Setting USB blaster
Create a new file at /etc/udev/rules.d/51-usbblaster.rules
copy and post
# Altera USB-Blaster rule to set mode to 666. SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
sudo udevadm control --reload-rules
6.setting QUARTUS_ROOTDIR in the shell
export QUARTUS_ROOTDIR="your quartus folder"
That's almust everything about it ....
Also share with google +
Enjoy & Regards,
Kqalea C
    mm520: the "Can't bind to TCP port 1309 - exiting" error message is probably due to jtagd already running. Kill it first and verify it's not running, then try your command again and check for possible other error messages.
    The suggestions in this thread doesn't take into account that different devices have different Product IDs (assumed to be 6001 in top post, this might be different for other users). Tristan's post has the same flaw. For a general solution, check your Product ID and use this, or add all known Product IDs to the udev rules. There is thorough instructions on this, along with trouble-shooting tips, here: http://www.fpga-dev.com/altera-usb-blaster-with-ubuntu/
