Improving NIOS2 performance, problems with memory map
- 3 years ago
Thanks for that. I've looked at the description of mgptop and I'm not really any the wiser. In the mean time I've got it to link by putting onchip memory just below the SDRAM so there aren't big gaps in memory space. There look to be a lot of settings that should improve performance (e.g. separate interrupt stack) but I'm guessing a lot of them may also just break the project. I'm reluctant to change anything I don't really understand.
Thank you for your response. I agree with your statement as it changes the algorithm behind that you do not understand.
Anyway, is linking onchip memory just below the SDRAM the workaround to bypass the issue?
Hope to hear on your feedback.
Thank you.
Kelly
Yes, I could put .bss, .stack and .rwdata in onchip RAM and throughput has improved significantly to where it needs to be. I think what I will try is switching to the 'full fat' NIOS2 as that includes caches, which is what I really need. It's a shame there's not a bit more granularity in some of these options.
