20 years agoIDT SRAM
hello
I am working with stratix II EP2S60. I cant find any documents about nios programming for sram (IDT SRAM). for example, how can i write a 32 bit data in known address in nios. thanks6 Replies
Dear,
Writing a 32 bit value can be easily done with a NIOS core. For example: You make use of a SRAM which has a 32bit databus. You can access this 32b bus with your NIOS core for example by use of a 32 bit parallel IO bus (GPIO 32 bit), called SRAM_DATABUS. Writing to this bus, you can easily do with following pointer instruction. The address is defined in your system.h file. volatile unsigned int * data = (unsigned int *) (SRAM_DATABUS_BASE); *data = 0xFFAAFFAA; The same procedure you can use for writting the SRAM CSn, WRn, RDn, .... Of course, take into account timigs (setup time, hold time,...) of you SRAM device. Regards Karel - Altera_Forum
You may also use the IORD/IOWR_32DIRECT functions
--- Quote Start --- originally posted by jdhar@Oct 9 2006, 11:37 PM you may also use the iord/iowr_32direct functions<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18611)
--- quote end ---
--- Quote End --- I use these 2 functions but i can just write to memory with IOWR_32DIRECT() and i cant read data with IORD_32DIRECT()
--- Quote Start --- originally posted by m_llaa+oct 10 2006, 03:30 am--><div class='quotetop'>quote (m_llaa @ oct 10 2006, 03:30 am)</div>--- quote start ---
<!--quotebegin-jdhar@Oct 9 2006, 11:37 PM you may also use the iord/iowr_32direct functions
--- quote end ---
--- Quote End --- I use these 2 functions but i can just write to memory with IOWR_32DIRECT() and i cant read data with IORD_32DIRECT() <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18618)</div> [/b] --- Quote End --- What do you mean you can't read? If you're not seeing the read strobes on the chip, you might be accessing a cached value. Set bit 31 in the read address to bypass the cache.
Hi gomiboy
I am using SRAM with 1024KB, then I have 20 bits for addressing. this is my simple program in nios. I can write and read. for(i=1;i<30;i++) { IOWR_32DIRECT(BASE_SRAM,4*i,i+1); for(beta=1;beta<5;beta++) { } alpha = IORD_32DIRECT(BASE_SRAM,4*i); printf("%x\t",alpha); } but if in second "for" I increse delay for example for(beta=1;beta<10;beta++) when I read from SRAM i can just read 0xffffffff - Altera_Forum
--- Quote Start --- originally posted by m_llaa@Oct 29 2006, 06:18 AM hi gomiboyi am using sram with 1024kb, then i have 20 bits for addressing.
this is my simple program in nios. i can write and read.
for(i=1;i<30;i++)
iowr_32direct(base_sram,4*i,i+1);
alpha = iord_32direct(base_sram,4*i);
but
if in second "for" i increse delay for example for(beta=1;beta<10;beta++)
when i read from sram i can just read 0xffffffff
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18990)
--- quote end ---
--- Quote End --- was anybody able to resolve these issues? i am using IOWR/RD_32DIRECT, in fact i copied and pasted above code into my program, but was unable to write to or read from the SRAM on the DE2 board. furthermore, when i attempt to read from the SRAM, it is overwritten. any ideas?
