17 years agoI2C real time clock (RTC) again.
Hi, Before the forum crashed there was an ongoing thread on this topic. Does anyone know if it ever got solved? Thanks, Alex
17 years agoThat is good news. I am still having problems though. I am trying to use a PCF8563 RTC and an opencores I2C insterface instead of the 1307 and the GPIO i2C. This is still proving problematic. I looked at the latest distribution and the 1307 driver has changed significantly. I don't know if these changes are related to Hippo's patch or not. I will need to look at the actual changes in detail to see what is going on. Maybe that will be a hint for the 8563. I am also going to try and wire in a 1307 on our opencores bus. It looks like the config.c was modified by Hippo to support either configuration. If I can get the 1307 to work, I should be able to get the 8563 to work. Thanks for the update... Alex
