17 years agoI2C real time clock (RTC) again.
Hi, Before the forum crashed there was an ongoing thread on this topic. Does anyone know if it ever got solved? Thanks, Alex
17 years agoMichael, here is everything I could mine from the old thread. There's not much I can do about the length; it is what it is.
Hi all, I am having trouble getting uClinux to recognize the DS1338 RTC on my hardware. The device is functioning and I can read and set the time with the i2c utils and it is keeping time, so I think the hardware I/F is ok. I have the following options checked in the kernel config: --- Real Time Clock [*] Set system time from RTC at startup and resume [rtc0] RTC used to set the system time [*] /sys/class/rtc/rtcN (sysfs) [*] /proc/driver/rtc (procfs for rtc0) [*] /dev/rtcN (character devices) <*> Dallas/Maxim DS1307/37/38/39/40, ST M41T00 When the system boots I get the following error message: . Linux version 2.6.27-rc4 ... . . /home/chris/nios2-linux/linux-2.6/drivers/rtc/hctosys.c: unable to open rtc device (rtc0) . . /> ls -al /dev/rtc* crw-r----- 1 0 0 10, 135 Nov 29 16:00 /dev/rtc /> Thanks and Good Huntin' cb hi cb, I've been following this thread as I am having trouble with the RTC also. I have managed to reproduce all of your data using a different RTC chip and with the same result I'm sorry to say. At the moment this issue has become a priority so I will be continuing to look at it. Please post anything you find and I will do the same.. Alex Hi cb and halfdome, Please check if you added i2c board info in arch/nios2/kernel/config.c, like that of arch/blackfin/mach-bf527/boards/ezkit.c. i2c_register_board_info() and I2C_BOARD_INFO("ds1307", 0x68) Cheer, Hippo
