16 years agoI2C interface on Linux (with MMU)
I have a few questions about I2C interfaces on Nios II on Linux with MMU.
I found this thread http://www.alteraforum.com/forum/showthread.php?t=18441 (though forum search for "i2c" or "I2C" doesn't find it). It is a bit fragmented, and difficult to follow. I have a Microtronix i2c interface. Should the OpenCores drivers work with this? I defined I2C_0_BASE, I2C_0_IRQ based on my custom_fpga.h I2C_0_FREQ is being a bit trickier. I assumed it should be the i2c bus speed; however, I discovered that it seems to hang the system at boot if I don't define it as the system clock speed (85 MHz for me).15 Replies
> Microtronix sent me their entire Linux distribution.
What Kernel Version does same use ? The only Microtronix Linux I saw up till now was based on a very old Kernel Version that uses a quite different driver interface. To work with the community, you would need to use the community distribution and if you want to use the Microtronix IP-Core supposedly you would need to port the driver to thr new Kernel interface. -Michael - Altera_Forum
I tried to find the kernel version today. Didn't see any sign of it. Any suggestions on where I should look?
I did notice that the files were dated May '07. at the latest. I did see some differences in the driver structure. I've asked the hardware guys about putting in the OpenCores I2C. If that fails, I'll be asking them for a bit-banging interface. - Altera_Forum
That is what I feared :( > If that fails, I'll be asking them for a bit-banging interface. That would be very easy for them as it's a simple Bit I/O port. -Michael - Altera_Forum
Well, I had them switch to the OpenCores I2C interface.
I pointed them at both http://www.opencores.org/project,i2c and http://www.niosforum.com/pages/project_details.php?p_id=111&t_id=18 as sources for the design. I compiled the kernel with I2C_0_FREQ defined as 400000 (400 kHz), and the ds1307 Real Time Clock support. The I2C initialized, and the RTC was read. I have not tried to write to the RTC, but the OpenCores I2C interface and driver seem to work just fine. - Altera_Forum
Great !
Thanks for letting us know. :) -Michael
