10 years agoI get a big noise when I echo the audio data from microphone
I designed a audio system in Qsys. I read the fifo data from the microphone input and write it to the audio write fifo. Although I can hear the microphone echo, it also generate a very big noise. I c...
10 years agoVerilog is *not* a procedural language. For loops don't do things one by one, they infer hardware for each instance of the loop - so that will not do what you want.
You need to create a counter (always @ ... counter <= counter+ 1), and use that to read from your fifo. EDIT: Never mind, that was C code, I misread. Ignore the above.
