10 years agoI get a big noise when I echo the audio data from microphone
I designed a audio system in Qsys. I read the fifo data from the microphone input and write it to the audio write fifo. Although I can hear the microphone echo, it also generate a very big noise. I c...
10 years agoIf I choose 16 bits as my audio data bit length, the max value becomes 65535 and min value becomes 0?
I am not sure the C program is running under 50MHz or not.. If it is, i think my synthetic audio signal is:
// for tri wave
int tri_signal = 0;
while (1){
for(int n = 0; n<12500; n++){
tri_signal = tri_signal + 5;
tri_signal = 0
// for sine wave (not smooth)
int sine_signal = 32767;
while (1){
for(int n = 0; n<3125; n++){
sine_signal = sine_signal + 10;
for(int n = 0; n < 6250; n++){
sine_signal = sine_signal - 10;
for(int n = 0; n < 3125; n++){
