10 years agoI get a big noise when I echo the audio data from microphone
I designed a audio system in Qsys. I read the fifo data from the microphone input and write it to the audio write fifo. Although I can hear the microphone echo, it also generate a very big noise. I c...
10 years agoA simple counter that increments and is reset to zero results in a triangle wave. A counter that alternates between the min and max values gives you a square wave. Make sure a complete cycle runs in about 400-500 Hz for the most audible tone on cheap speakers.
