14 years agoI can't make " New-Nios II Application and BSP from template".
Hi,all. I tried to make " New-Nios II Application and BSP from template", but I can't make it. I selected the ".sopcinfo file", and typed "Project name", and choose "Blank Project" at the pro...
11 years agohi,FKDKNJ.
Have you solved the problem? I used the command shell to create my sopc project, when typed in ./create-this-app , an error appeared "Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]" Can you share you experience with us? Thank you very much.
