14 years agoI can't make " New-Nios II Application and BSP from template".
Hi,all. I tried to make " New-Nios II Application and BSP from template", but I can't make it. I selected the ".sopcinfo file", and typed "Project name", and choose "Blank Project" at the pro...
11 years agoHi,
I know that your post is three years ago but I have encountered the same problem recently. I wonder if you have found a solution. If so can you share it here, please? Best Regards, Mustafa --- Quote Start --- Hi,all. I tried to make " New-Nios II Application and BSP from template", but I can't make it. I selected the ".sopcinfo file", and typed "Project name", and choose "Blank Project" at the project template, I click "Finish" at the last. As soon as I clicked , Creating Project begin , but 10 seconds later "Error Creating Project" window appears. The error message is "Failed to execute: ./create-this-bsp --cpu-name cpu --no-make". Do you know how to solve this probrem? --- Quote End ---
