11 years agoHPS QSPI flash programming
Hi, I have an issue with QSPI flash programming by quartus_hps utility. I use EDS 14.1 and run quartus_hps in its command line. I've made custom preloader to boot from QSPI flash and program the ...
11 years agohmm... how did you do that..? did you entered Qspi -> HPS -> parameters -> Peripherial Pins and then under the Quad Spi Flash Controller pane you slected "HPS I/O Set 0" ? i do that and it simply adds few pins to my HPS object. did you connected to these pins something or left them unconnected?
