11 years agoHPS QSPI flash programming
Hi, I have an issue with QSPI flash programming by quartus_hps utility. I use EDS 14.1 and run quartus_hps in its command line. I've made custom preloader to boot from QSPI flash and program the ...
11 years ago --- Quote Start --- are you going to test performance, because i am interested how much write takes? --- Quote End --- Do you mean speed of writing? I think of QSPI to use it for boot purposes. There is NAND flash to use it in work process, but I can't find any Altera examples for NAND. For now I try to learn working with NAND controller. Here is my topic about this, if you are interested in: http://www.alteraforum.com/forum/showthread.php?t=47631 (http://www.alteraforum.com/forum/showthread.php?t=47631)
