10 years agoHPS DDR memory access for Preloader and UBoot
I have a Cyclone V board with 1Gbyte DDR3L memory connected up to the HPS. I am loading U-Boot through the Preloader using UART0 and YModem transfers from my PC. This all works, and I can see U-Boot ...
10 years agoA further note: once the DDR memory is "corrupted", I can restart the debug instance within DS-5 and get through the preloader as far as (and including) spl_board_init(), and then look at the 0x100 0040 memory window again, it's back to saying "U-Boot 2013.01.01 for socfpga bo" in the text string at 0x100 0020.
So clearly the DDR memory isn't getting corrupted, but DS-5's and the ARMs ability to read it has gone once it has the program counter moved to that addresss space. I wondered whether it was the processor Instruction Cache that was causing the problem, so I disabled that using the control register in CP15 (as per ARM documentation), but exactly the same thing happened. Any help or comments would be greatly appreciated.
