16 years agoHowto Assign clock to node?
Hello, i built a NiosII system in SOPC Builder, which has several i/Os. Then i compiled it and want to integrate in Quartus now. Fot the Connections i goi to assign pins and connect the norma...
16 years agoWhat board do you have? Don't rely on the documentation for the pin number, look at the board schematic instead.
The classic time analyser or Timequest are simulators. The clock you create with those systems are for simulation only, and to run your design on an FPGA you need that external oscillator.
