21 years ago
How to use the niosii custom instructiont?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif hello,
I did a niosii custom instructiont mode,and input it into my system via SOPC,but I ran
into troublesome when I oprate the custom instructiont mode in NIOSII IDE.
According to the Example B(p2-1,Bit-Swap Custom Instruction) of Software Interface of
"Nios II Custom Istrucrion User Guide" ,the custom instruction used in applacation code
should be as follows the form:
1.#include "system.h"
2int main(void)
int a = 0x12345678;
int a_swap =0;
a_swap= ALT_CT_BSWAP(a);
return 0;
According to this kind of form,my custom instructiont mode in applacation code do not
work !
I fined the Another example of User Guid is different from this form.
alt_u8 zeros_hardware[NUM_SAMPLES];
alt_u32 numbers[NUM_SAMPLES];
void hardware_leading_zeros(void);
compare_leading_zeros(void);
...# ifdef ALT_CT_LEADING_ZERO_DETECTOR
compare_leading_zeros(void);# endif ALT_CT_LEADING_ZERO_DETECTOR
zeros_hardware = alt_ct_leading_zero_detector(numbers);# endif ALT_CT_LEADING_ZERO_DETECTOR
When I put my custom instructiont mode into the leading-zeros-detector example running
well ,my custom instructiont mode can work well! but when I put my custom instructiont
mode into my system without sysid,it can not work again.
why ?!
whether the custom instructiont mode in applacation code want a limited_times sysid or
other condition?
thank you. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
[email protected]
[email protected]
1 Reply
    I don&#39;t see any reason why the SysID peripheral would have anything to do with it (I suggest you keep it in your design to make sure you are using the correct hardware). One thing to make sure of is that you have the correct name of the custom instruction (in your case " ALT_CT_BSWAP(a)"). If the C compile occured with no errors then this wouldn&#39;t be the cause.
    Can you describe further what you are seeing and how you set up the custom instruction?
