22 years agoHow to use sockets with the Stand-Alone LWIP?
Is it possible to use sockets with the Stand-Alone LWIP? I would like to use the web-server from Altera for the MicroC/OS-II which is based on sockets but I’m not able to bring it to work. Does anyone have experiences in this topic? Bye, niosIIuser2 Replies
Sorry the answer is No. The use of the sockets API requires a threaded environment.
Below is the quote from the LWIP documentation, which can be found in the file rawapi.txt in the src/downloads/lwip-0.6.3/doc directory Raw TCP/IP interface for lwIP 0.5 "lwIP provides two Application Program's Interfaces (APIs) for programs to use for communication with the TCP/IP code: the sequential API (often just called "the API") and the raw TCP/IP interface. This document is intended as a description of the latter. For lwIP versions lower than 0.5, this API was not documented. The sequential API provides a way for ordinary, sequential, programs to use the lwIP stack. It is quite similar to the BSD socket API. The model of execution is based on the open-read-write-close paradigm. Since the TCP/IP stack is event based by nature, the TCP/IP code and the application program must reside in different execution contexts (threads). The raw TCP/IP interface allows the application program to integrate better with the TCP/IP code. Program execution is event based by having callback functions being called from within the TCP/IP code. The TCP/IP code and the application program both run in the same thread. The sequential API has a much higher overhead and is not very well suited for small systems since it forces a multithreaded paradigm on the application." - Altera_Forum
Hello rugbybloke,
Thank you for this hint now some thinks are clearer. Bye, niosIIuser
